So some background on the problem. One day parking brake stopped working. If you pull the cable it looks like everything is working on the caliper but it does not grab. I said f-it and didnt worry about it. About 2-3 rides later the rear brake got real weak. It will slow you down but will not lock up the wheels. So i went and put new pads on(old ones were worn about half way) and bleed the brakes. If a push the rear brake the piston will come out and go back in. The problem is the piston needs to be out about a 1/4 more. So the pads dont even touch the rotor. What am i overlooking:mad: was planning on riding today. :(
Discussion Starter · #2 ·
also i tried to unscrew piston to get it to stick out a little further and it did not come out. should it?
RF Moderating Team Member / Wheelie Master
Yes , try to unscrew it more.
it just spins freely either direction now. its all the way in. But if i push the brakes it comes out then goes back in like its working.
ya i guess its stripped out. my buddy has a yfz450 caliper. will it fit?
My rear seems pretty weak as well. Put new pads on it. Had to screw the piston way in to get the pads on.
Almost seems like a pedal positioning problem. Not spongy like it needs bled, but you have to push the pedal WAY down to get any real stopping power from it.
