1 - 18 of 18 Posts
#327 "After Hours"
I need to raise the ride height in the rear of my Raptor. It sags a hair below level when I sit on it. I only need to raise it about a half inch to a inch and have plenty adjustment left in my shock. Will I be able to get this out of my shock?
#327 "After Hours"
Alright thanks man.
#327 "After Hours"
You think I should use a spring compressor to take some pressure off the spring? Or does it turn pretty easy without it?
if you take the quad and put on a stand,to let swing-arm drop down till all possible pressure is off spring,it would be easier to turn threaded collar.you shouldn't need spring compresser.
#327 "After Hours"
Thanks!
#327 "After Hours"
Last question before I try this. Anything I should know about this? Anything like reverse threading or some kind of oddity? Best way to do it? Do I need to buy a spanner wrench or is there other method?
Banned
Put it on a stand like the other guy said then if you don't have a spanner then take something flat and a hammer and knock the top flat nut loose, once loose you should be able to turn it by hand i always did. Then knock the top nut back tight and your done
#327 "After Hours"
I'm just shooting for it to be level. As it sits right now its a little low in the rear with me on it, not by much though.
#327 "After Hours"
No, I'm going to mess with it tomorrow. One of the neighbors kids brought his TRX over and needed some help with it so I gave him a hand. If the weather works out for me I'll give it a whirl tomorrow.
Once you have the top nut loose and all the pressure off, grab the spring itself instead of trying to turn the top, it should turn pretty easy.
#327 "After Hours"
Discussion Starter · #18 ·
Finally got around to doing this. I raised compressed the rear spring about 1/2 inch and expanded the front about 1 inch. Sits perfect now. I only road it for a short time after but it seems to keep the front down alot better and handles ever better. Now I just need to fine tune it and hopefully she'll do alot better in the curves and ride height.
1 - 18 of 18 Posts
