Anybody have a pretty accurate weight of the 700's rear shock? Thanks
opeythaballer10 · Registered Joined Apr 1, 2009 · 17 Posts Discussion Starter · #1 · Apr 5, 2011 Only show this user Anybody have a pretty accurate weight of the 700's rear shock? Thanks
lucky 69 · LOOK UP IN THE SKY ITS A BIRD, A PLANE, THAT'S THE Joined Feb 7, 2010 · 547 Posts #2 · Apr 5, 2011 (Edited) Only show this user for a stock rear shock itself , 5lbs should be pretty close. if you were wanting the shock wt itself?
wiigstyle · Registered Joined Nov 14, 2008 · 112 Posts #3 · Apr 5, 2011 Only show this user Weight of stock se version shock is 8.5lbs. with spring. Josh WiigStyle Racing Suspension
