rear skid plate bolt threads stripped on the swing arm any ideas to fix????? rear holes on the rear axle I retapped and are ok..the fronts have a sleeve for the gaged nut which is stipped I need to fix this so I can put my skid plate back....thanks :help:
I had to use a thread setter. This a very similar to a rivet, but sets a nut in place. Not sure where to get this though because my father in law had one. Maybe check the autoparts store.
Good luck.
1/4-20 SAE bolts are just a hair bigger than the stock metric, I ran a 1/4-20 tap in the stripped holes and used new stainless bolts. It worked just fine until I went drag only and removed all that stuff.
