Rebuild engine or buy rebuilt?
1149 Views 2 Replies 2 Participants Last post by  SaiyanHD
I purchased a used 2020 Raptor 700 for $5.2k, had some broken plastics due to being flipped but it ran good. Before I bought it asked the guy when is the last time he did an oil change and he said “it could probably use one by now”. I changed the oil like I always do when buying a used ATV. Ran 15w-40 at first but it gave me a small knock after a few hours of use, so I changed it 20w-50 synthetic and the knock went away, didn’t think much of it and rode it for about 10 hours, no issues. I noticed the quad was taking too long to start (10-15 sec) so I adjusted the valves and it was knocking once again. Took it to a shop and they said there was metal in the filter and oil and it’s most likely the crank bearings going bad but they would need to take it apart and charge at least ~$400 to confirm.
My question is, should I find someone to rebuild my engine with the a new crankcase and bearings (case is $600 alone) and HOPE the case is still in shape? Or, try to find a rebuilt engine and swap it out? Does anyone know who on here sells rebuilt engines?
Video after valve adjustments
Any input would be appreciated, thanks!
Personally I would rebuild what you have. Call around get some quotes or do it yourself. I always find it better to build a motor then you know what you have. Maybe someone will chime in. I have always had my motor done by a buddy with a shop. But he sold out so next time I’ll be doing myself. Good luck. 🍻
Reactions: 1
I was thinking about just getting it rebuilt as well since it’s still a newer engine, I would love to do it myself but have very little experience in engine work.
Thank you I appreciate your response!
