Hi guys i recently purchased a 02 Raptor 660, which i found out because of the vin# from what i read the 10th number is the year and it showed a 2, person i bought it from listed it as 06. i noticed when i started looking for parts that 660 stopped in 05 i believe.
anyway i bought it cheap because the crank broke through the crankcase. i learned how to shift gears on one of these when i was younger, which lead to my motorcycle addiction i have now. (06 cbr 1000)
i've watched a couple videos on the rebuild since i'm pretty mechanical and didnt seem like it would be to hard to get this bad boy up and running. First issue i noticed was they stopped producing the crankcases for these badboys which sucks.
i want to make sure i'm going in the right direction before i pull the trigger and buy the parts to get it running again. so far i've found this combo as what i think is a good deal since all the crankcases that i keep finding say the chain guard is broken on them. So i've been a little wary of buying the ones i've seen on ebay.
My way of thinking at the moment was, since the current case is obviously broken, take this kit and piece the rest of it back together with what i have on the broken motor right now. But i want to piece this back together right so the bike last for years to come. So any suggestions of parts to upgrade or buy while its open please let me know it would be greatly appreciated.
also is their a way to avoid it cracking the case how it did, cause it literally split it straight up the middle of both sides of the cases.
As long as cylinder head is in good shape and I use this kit. What direction should I go with redoing it springs etc??
I plan on keeping this for a while so I wanna make a solid build so while I have the case split are their any must repairs or upgrades to do for stability reliability?? Or anything in general that needs to be changed or fixed that are common issues or advice that you wish you had before you started building it.
change thread namein case I need more help during install. Will start pulling out engine in next day or two see damage of old internals.
Since it's apart, you can get rid of the top speed limiter.
With the clutch cover off, towards the of rear of the case, a wire harness connects to a sensor above a gear with square teeth.
That sensor is counting the teeth and rpm of that gear. Once it says it's too fast, it pulls timing, limiting the top speed. Unplugging it will not work.
You need to grind most of the teeth off that gear, leave 4, evenly spaced.
That way it will trick the sensor into thinking that gear is turning very slowly, as there are now only a fraction of the original number of teeth for it to count, and you'll in turn gain a few more mph on top end.
I would also do the reverse limiter removal, but that is just wiring, and not inside the engine.
Also, adjust the valves while you're at it. They're easy, the old style Allen head set screw and lock nut.
I also post in all the 660 threads, search and do the "clear tube method" for adjusting both carburetor floats.
It's been around the forum for years, and I'm about to do it on a 4th 660.
It makes a noticeable difference.
trying to show my 12 yr old how to wrench. He took off all the bolts and fairings. Showed him how to take off all the cables. Slowly but surely will get it up and running.
Good luck on the rebuild, this forum helped me a lot. This is the first time tearing into an Atv motor but I’m just about finished with my Raptor..need a chain and sprockets and some random parts and it’s ready to ride.
I definitely appreciate the help guys. As far as the head, should I go ahead and get new springs and valves since I’m replacing the bottom end? What head kit would be suitable for the 686 bore kit... want It to be more reliable than anything.
What I rebuild carbs, they said it was running before it popped the motor. I Detached it from tubes and pulled it to the side for now didn’t wanna mess with the cables etc attaches.
also I'm reading on one way starter bearing, is this while I have the cases open?? purpose of changing?
Here’s what I pulled out today. One of the rocker nuts was completely off. What a pain in the ass all those Allen bolts are, any alternatives when I go to put back together.
Advice on this head and the rocker would be greatly appreciated...
on the good ole flywheel. Decided to whip out the old probably hasn’t been touched in 15 yrs engine stand. Was annoying me moving around taking the hard stuff off. Going to ace to find bolts to fit it to the mount. And continue another day. Slowly but surely.
Can someone chime in on this point. As far as the tranny, I think it looks good. The clutch basket plastic gear is obvious needs to be replaced. Only thing cheaper I have found is the steel gear to replace it that needs to be pressed in.
and than the Cylinder head. Do I just send this to get rebuilt or order new valves and a new cam while I have it open?? This is really were I’m more stumped....
I want it reliable To take care of for a couple years and I ride more motorcycle pretty hard when I get it so just don’t want to waste money where I don’t need too.
Previous owner blew the counter balance through the cases. Have the whole bottom end ordered. Trying to figure out what to do with the head. Anything rebuildable??
What's wrong with the head you have?
Is it not rebuildable?
Cam bearing surface worn out?(I can't tell from the pictures as they aren't clear enough)
If not, it should just be a valve job.
the covers aren’t matching. Previous broke that little bolt that’s hidden in the cover so that little bottom piece was jb welded on to hold it in place. From what I’ve been told the cam has possibility of moving around due to the numbers not matching. Don’t feel any grooves were the cam goes, but their are scrape marks on timing chain side. As well as one of the rockers was missing a bolt.
Gotcha
I'de measure the cam bearing surfaces and see if they are in spec.
You can use a spring loaded, locking bore gage like this to measure it, and rotate it to measure at multiple points.
A machine shop could do that for you.
This is a bore gage in a rod, but the principle is the same.
After you lock the gage, then remove it and measure the gage with a micrometer.
Also, does anyone make inserts/ bushings for 660 cam mounting points?
If so, that would be cheaper than a new $700 head.
Well that’s kinda where we are at and discussing. Have a friend that mentioned exactly the same thing micrometer as he and his dad built a couple bikes when he was growing up. But as i researched about the numbers not matching and discussed with his dad. Came to the conclusion that it might be better to get another head than repair this one. Something about where the cam lays on, It’s hard to match with a different cover as It wouldnt hold the cam in place correctly. On top of everything I mentioned, also found helicoils on the two bolt holes that come up from the cylinder to hold the head. Having him take it to the machine shop anyway to see what they suggest.
So the guys looked at the head said I can reuse it again. That looking at the Head gasket marks from the previous fitting it sealed really good doesn’t need to be resurfaced. The valves were taken apart, they were seated good as well and checked. He was able to weld the piece that everyone breaks on the cover. I’ll post up pics of the head when I get it back. Everything else should be here by next week to start assembly
oh and have to do a time sert on one of the two holes for the screw that comes up from under.
anyone know what time sert to order so it matches the screws??
Time sert is ordered. Most of the parts coming in this week. Just little things here and their. Anything important to look out for during rebuild? Or to do while engine is open for extra safety/protection??
also is it two different loctite that you use for assembly or one? Which ones or one
Don't use permanent loctite.
Use anti-sieze on any and every faster that thread locker is not required on.
Use non synthetic/dino engine oil on the cylinder wall(rings break in better with dino oil that allows more friction than synthetic oil) and use dino oil for engine break in.
Assembly lube all over the cams.
Adjust the valves after assembly.
If the clutch cover is off, grind all but 4 teeth(evenly spaced) off of the speed limiter gear(it has square teeth that a sensor counts, and the sensor is on the end of the wires that go into the top rear of the clutch cover).
With less teeth on the gear, the sensor will never count enough teeth at max rpm at top speed to pull/retard timing, which prevents the engine from going any faster.
Simple trick to gain a few rpm and therefore mph at top speed.
Loctite comes in several different thread locking strengths - identified by the actual liquid color. Red is high strength, blue is medium. For one-way to flywheel and flywheel to crank we recommend red.
IMO if coming undone is catastrophic I use red. Else, blue or nothing.
