Discussion Starter #2
Nvm i just grounded the green and white wire out to the negative terminal. It doesnt ever come on any more but now there is reverse limiter.
Your logic is backwards. With the green/white wire grounded the reverse light should always be OFF and the reverse RPM limiter should be permanently eliminated.
Did you cut the wire or just ground it while leaving it attached at both ends?
That large fuse (assuming that 's what it is) that fell out should not belong to the Raptor.
