Short across the solenoid's (start relay) large lugs with a screwdriver - ignore the sparks... If it turns over then the solenoid is bad, If not, then the battery is bad/undercharged, battery connections or cables are dirty/loose/corroded. starter has failed or engine is seized. My bet? Battery or cables.
