Ok so i got the one way bearing installed and put back together. I went to start it and all i hear is a click coming from the relay by the battery. What could this be? Also when we took the starter off theres these 2 copper/wire/rubber rings that im not positve exactly where they go. Any help with these? they jst kinda fell out when removed the starter. Thanks
Stating the obvious... but make sure your battery is fully charged too!;)
tested battery and starter and both are good. The relay still clicks. The fuses are good on relay. What could this be:mad:
You are most likely talking of the oring that seals the starter into the case...........
And if there is a click but no action of the starter, you most likely either dont have it hooked proper or no ground. Check with a test light when you hit the start button to see if you have power at the starter main terminal.............
