1 - 19 of 19 Posts
I needed to replace my 38t since it was gettin thin in the skin and so I already had this 36t here for when I run 18"s at the races so I just swapped it out. Feels just like the 15t difference over the 14t, and its that much better since mine is modded so much :thumbsup:. My chain dont rub the hub either :thumbsup: like I heard some do.
Sweet man. :thumbsup:
My set up:
11:1 Wiseco
Track porting
stock cam and valvetrain
GYTR intake
GYTR exhaust
Dobeck Gen II
Renthal 15t/36t sprockets
YFZ tires
2" stem
MSR CR High bends
Extreme Fabrication nerf bars
What size are the yfz tires?
whats would be a good size sprocket for woods racing??? 15 39? 15 38? or stay with 14 or??
how does that 15/38 work for bottom end??
Hi. I also wanted to change my rear sprocket. I've never had it off before so my question is? After you remove the tire, chain, and the 4 bolts on the sprocket, will the sprocket just slide over the wheel hub? Or is there a lot more to it. Thanks.
I just loosened the chain, took the 4 bolts out of the sprocket hub, took the castle nut off the axle that holds the wheel hub on and slid hub/rim/tire off, wiggle the sprocket over the sprocket hub and slid it on off the axle, put the new sprocket on, and reversed the process.
My stock and 36T JT sprocket both fit over the hub......dont know if the renthal does but i thought you guys might like to know the JT fits over the hub and the chain clears the sprocket hub fingers good as well....the chain is real close though.
Im running a 14/36 right now, but I think Im gonna change to a 14/37, and go to 21 inch tires(when mine wear out)
ya I have the 36tooth rear on my bike and it looks like it is really close to hitting the hub so close I can't tell if it is or not. I can't hear any noise while I ride the bike and don't notice wear marks so I'm guessing its not but its damn close
I'm running 15-37 with 22" rears. No power problems with a Trinity Stage-3 system. Haven't gotten a top end speed reading yet though. We just got 5 more inches of white crap last night. :mad:
1 - 19 of 19 Posts
