OK, so i just installed my durablue x-33 axle, direct drive lock-out clutch cover, Ct full exhaust. My one way starter clutch is wore out, i've priced the labor and it ranges from $200-$250. I'm pretty mechaniically inclined but it this process one that is easy enough for me to do?
its reallly not bad to do if you have a puller to take the flywheel off i didnt have one and took it to the local yamaha dealer and had the cover off and they only charged 15 bucks to pull it off
If you've done the other, this is no harder... pulling the flywheel is the one PITA, but it just takes patience.
