1 - 15 of 15 Posts
Were is a good place to send a cylinder for resleaving.
I have a couple of local shops that can do it for me, it's not the kind of thing I typically worry about sending to a builder across country.
I think I get charged 40-50 bucks, but prices of 80 aren't out of line.
Kenz just priced it out the door for 200 + piston
everything - piston. So I am figuring about 400 or so for everything.
All I know is that it is cheaper than when I did my sled a 5 years ago. Fing ported twin cylinders. I should of put the V-max 800 in at that point:)
will know more tomorrow after I take it to work and mic it out after work. Would go tonight but Bud Light would not give me a good reading, LOL. If it is still within specks,taper and out of round wise, I might do a light hone and get a piston, 11:1.
Damn hk.... if I knew you were gonna do that I have 2 cylinders here that are bad 102 bores on them needing a new sleeve
Discussion Starter · #13 · (Edited)
I hope i dont have to send it out. will know more when I mic it all out. It is just a habit from from when I raced boats and snowmobiles. I just check on prices and hope for the best and prepare for the worst.
Discussion Starter · #14 ·
Well it came out to bore diameter of 102.089mm. Looks like I will be running it till it wears out.
Thanks NateDiggity.
1 - 15 of 15 Posts
