Hi Gents,
I've been on this site for the past 4 days trying to get this rev limiter problem nailed. Some people say cut the green with white stripe and ground it......
ground which end?
then others say....just cut it......dont ground it......
then other say, buy the product from ripper blah blah......off of ebay.
So I cut the wire, stripped both ends, added an extra length of wire and then ran that to a ground on the bike. took off the parking brake cause I read that that will also trip the limiter.
ALL THE RESULTS ARE THE SAME
After starting each time I tried a fix.....the rev light stays off until the bike starts to warm up....then as I try to slow give is gas......
I DIES.......OR WANTS TO......
ITS NOT UNTIL I REALLY GIVE IS SOME HARD THROTTLE THAT IT WILL REV UP AND STAY RUNNING.......of course pissing off my neighbors each day at the same time........
thoughts???
re-direction........
carbs are clean with new jets but I had the problem before the new jets anyway........
I'M EVEN TIRED ABOUT READING THIS PROBLEM UP HERE......
ALMOST TIME TO THROW THE TOWEL IN FOR A SUZUKI OF KAWI 450 AND BE DONNE WITH IT
HELP!!!!!!
ground which end?
thoughts???
HELP!!!!!!
