1 - 11 of 11 Posts
Maybe I'm just dumb but I'm stuck on the spring.... how do you put the spring on? Thanks in advance.
https://imgur.com/a/VKYucxw
Remove the lever, install the spring, replace the lever.
The end that points toward the case is supposed to be tucked under the stator cover
Agreed - the leg that bends in towards the the case should be captured in that little nook, close to a quarter turn counter-clockwise from where it currently is in the picture.
I don't know 660's but i think it needs to be rotated another 1/4 turn counterclockwise.
Reactions: 4stroker4life
Right i think there is a little hole right there for it. Just wanted confirmation before I go mess with it in the snow for a hour.
IDK about a hole, I was talking down below the case and the clutch lever casting notch.
1 - 11 of 11 Posts
