1 - 2 of 2 Posts
I have a 2005 raptor 660 and when it’s in gear or in neutral and you rev it the reverse light comes on and it bogs out at higher RPMs.
The green/white wire plugs (pushes onto a stud) on the reverse switch down by the output sprocket. It is loose or dirty/corroded. Clean and tighten the spring contact. Else, just ground the wire to the negative battery terminal.
Welcome to the forum! BTW, all of this info is well documented in the Stickies - especially "Most Common Raptor 660 Problems Explained".
1 - 2 of 2 Posts
