I have a 01 raptor 660 and reverse light stays on all the time? It's not mine it's a friend's. I checked the white green wire down at switch and if I ground it, it hot? Has full batt volts? So if I ground it it sparks and melts? If I connect it to the switch it does nothing so I pulled switch and checked for continuity thru it both ways closed and open and get nothing either way? But if I get a new switch that has continuity one way to ground it's gonna fry the wires and switch?
Discussion Starter #2
I figured it out lol the guy had put a new battery in it and hooked the wire supposed to be grounded to the hot post! Lol easy fix but switch is still bad so ordering new. Thank u anyway I'll be back here great site!
Glad you found it. Welcome to the forum!
