reverse rev limiter
3465 Views 9 Replies 7 Participants Last post by  sledhead907
how do you remove the reverse rev limiter from and 01 raptor660? :help:
1 - 10 of 10 Posts
splice into the green/white wire and ground it. Its located next to your front sprocket. your done and its cost a quarter for the splicer. good luck,
Max
Max
Damn, thats all you gotta do?
Assuming that your 01 has a reverse rev limiter to begin with.
i read on another thread to unplug the sensor and ground it, that made the reverse light stay on and the rev limiter kicked in in all 5 gears including reverse,it's an 03 660 se.......still looking for help to...........
u can unplug the parking brake sensor but not the reverse...and you don't have to ground the parking brake sensor when unplugged.
well i bought the ripper racing module,it don't work, went over the wiring 10 times to double and triple check wiring :'(tried unplugging the parking brake sensor,didn't work. tried closing loop and that didn't work either.tried clutch sensor that didn't work either,tried grounding wire on sensor that didn't work either....can somebody tell me wtf is wrong withthe ideas of this f-in limiter.....ready to get rid of the damn thing cause reverse ain't worth a f--k!!!!!!!!!!
i just got a race ignition cdi and it got rid of the rev limiter in reverse
Mine worked as advertised...
Assuming you have everything spliced right, you might have a defective unit. I would get a hold of ripperracing and I'm sure they will exchange it for you no questions asked.
1 - 10 of 10 Posts
