ok so i just got home from a good ride the dunes but all i get is wheel spin so i am now changing my tyres but was going to get a second set of rims for when i ride this area as i ride a variety and dont want to shred my good ones when i out on gravel
so my question is
1. should i stick with stock with rims?
2.are maxxis razors a good tyre for what i am lookin at
also does anyone know what offset and stud patter i should look at and will the added weight of a wider rim make much difference??
thank you
Ben
Discussion Starter · #2 ·
also i am just looking at getting a replacement set of rears
For 90% sand and 10% gravel, I would look at a paddle-type tire. Not a true sand tire, but something like a Pure Sport Realtor:
The bolt pattern is 4/156 for the front wheels, and 4/115 for the rear wheels. And no, You will not notice added weight from a wider wheel. The tire weight is what you will notice (if any).
I ride the same terrain and percent as you.
I have the stock tires and rims for the odd times that I ride hardpack\gravel. I have a set of paddles on the back for the majority of the time, as I ride sand dunes. Im running Skat Trak 8 paddle haulers in 20-10-10 on Douglas .160" black label rims. Ive been using the stock front rims and tires in the dunes and they seem to be ok. I want to get a set of ITP Sand Stars for the front in 21-7-10.
I would suggest having a seperate setup for dirt and dunes. No knobbie tire will ever come close to the traction of a paddle tire in the dunes. That Realtor your looking at is gonna be a stiff, heavy tire. It wont do well in the sand.
i didnt want to go a paddle because the 10% is not really gravel its sharp hard rocks that are around the dunes and on some of the tracks, what with rim are you guys using
Ben
