I went to put on my protaper cr-high bars and they are alot lower than the stock bars...i bought them thinking they would be higher than stock but i am wrong. what riser would you guys recommend? i want my bars higher than stock without modifing the cables.these bars are 7/8" dia.
http://www.rockymountainatvmc.com/handlebarinfo.do
has all the manufacturers bar measurements,
i have a set of renthal bars with the fourtraxx bend, similar to the raptor bend, just a bit taller.
the cr high look to be about 2 inches lower than the raptor bend, a 2inch riser should get you to about stock
yeah i seen that i was in a hurry to place my order....im thinking the Rox pivoting riser 3 1/2" one. Will my stock cables be ok? so really it would only be an 1 1/2" taller. I also have a diamond J front end widing kit also so that will be taking some more of my brake line slack.
