i need a new right headlight and i bent my handlebar.... any suggestions on a good replacement? i was thinking about protapers. and where can i get a stock headlight other than the dealer?
You should be able to use all the stock hardware and you will need some grips and grip glue. I may be wrong but I thought the protapers are available with the raptor bend. It's really personal preference when it comes to bar bends Bush, I wish I coupld help you there. Good luck!Bush_Pilot said:im pretty sure im getting the pro taper SE but i cant decide what bend.... what all will i need to install them? just the bars and some grips? whats a good bend to get thats close to stock? atv mid?
Someone had posted that anything other than the Raptor bend would rub the tank cover.Bush_Pilot said:im pretty sure im getting the pro taper SE but i cant decide what bend.... what all will i need to install them? just the bars and some grips? whats a good bend to get thats close to stock? atv mid?
