1 - 12 of 12 Posts
I recently cleaned my carbs and sprayed these rubber seal things on top of the carbs with carb cleaner. I later learned that i shouldn't have done that. Anyway now when i put the carbs back together and on it ran like crap. Popping like crazy and seemed to have no "getup and go". I couldn't pull a wheelie. So do I need to replace these? How much do they cost, I can not find them on the internet?
Are they ripped? Just depends on if you ruined them or not if you need new ones. I would think you messed up jetting or you didn't clean the carbs properly.
No they are not ripped, but i am having extreme difficulty tucking them back under the covers so I suspect the carb cleaner softened them? Is there a certain way to get them under the black plastic cover because they are larger in diameter than the lid or carb
they should have some kind of "ring" that fits in a grouve in the carb body if i remember correctly. There is some excess material i believe. just make sure they are layed flat with no wrinkles. Carb cleaner mainly hurts them when they are soaked in it, it eats them up.
ok mine were not soaking so maybe they are fine, but I still cant get then to seat properly. Any tips/tricks?
The carb cleaner has swelled the rubber.
Put them somwhere warm and dry for a few days and see if the shrink back to size.
Never use carb cleaners,or solvents on rubber parts.
PB blaster swells rubber fast too.
If you just barly spray them with carb cleaner they will swell up. Like said above put them in a warm sunny window to see if they shrink, or just buy new ones.
They are calld vaccuum slide diaphrams.
I would think that you might want to try putting them in the freezer for a hour or less. Molecules contract when in cold environments. Heating them up or letting them sit in the sun will make the molecules expand. Also might want to spray them down with some silicone spray.
Try washing them in warm water with soap, and let them soak, it may help get rid of the cleaner that disolved into the rubber...........
I did that once years ago with a Wolverine. Ran just like your discribing, the only way we could get it running properly again was to replace the rubber diaphrams.
Good luck
i took them out of the carbs today and let them dry for a few hours. Then I put them in and they fit perfectly. Thanks so much!
1 - 12 of 12 Posts
