I've been learning a lot from you guys on here and this is the first time I haven't found a problem I'm having posted on here already. Alright just had the carbs cleaned and now when its cold its running like a champ but after about 10-15 mins of riding it starts spitting and sputtering and backfiring like its running out of gas but the tanks full, and ideas suggestions ANYTHING will be greatly appreciated. O and its an 01 completely stop with the exception of DG performance header and muffler.
I would say it is rich. As the motor warms up the air thins out. This pushes it even more rich and causes the running issues.
Next time it starts sputtering, remove the gas cap - does it clear up? If so, you have a plugged gas cap vent or vent tube.
Are you talking about the the intake boots coming off the front of the carbs??? If so that would make since cause I had the hardest time getting them back on and tightened the S*** out of it so it wouldn't pop off. I'll have the mechanic try and redo it. Thanks guys I'm completely lost on the duel carbs.
