1 - 16 of 16 Posts
Anybody got idea?? Im Stumped!! Running probs Please HELP
I have a stock 07 700r se. I ride with about 20 or 30 people all diff kinds of atvs on some pretty rough trails. I run pretty slow when i hang with tha group. one nite it started smoking real bad and missing while i was jus puttin round i could run it hard and it would straighten out except for when i let off the gas it would smoke acted like a carb loading up its fuel smoke i dont know much bout the fuel injection i changed the plug , took the injector out , took air filter off and cleaned everything. i changed oil and gas and put some lucas in it , i only run 93 octane. it will crank and idle fine unless u let it set for bout 5 or 10 min then it floods out and fouls my plug. i put a new plug in it and took the air filter off and ran it on the highway one nite and it ran fine i let it set in driveway and idle and never had any probs i put a new air filter on it the next morn before we left to ride and it started doin the same thing. i know its not the rings cause it only smokes sometimes Anybody got any ideas??
We need alot more information then whats given. Starting with the mods done to the quad. Is it stock? Does it have a fuel controller? Normally you will see fuel smoke under load not when its idleing.
If its light white bluish grey smoke that would be oil smoke.. Fuel smoke its a really black smoke. Sounds like you need some rings..
Not necessarily, but its not the definite problem either. You said you had problems with it idleing? Try checking your TPS sensor
Maybe a valve seal... I had a 2006 that was doing something similar.. Sometimes it would smoke, other times it would stop.. it was pretty random.
1 - 16 of 16 Posts
