1 - 11 of 11 Posts
Hey there just wondering what u guys think my quad will dyno at just installing my dmc force 4 to the list of stuff.
I believe the elevation is 2850ft or 870m
63-66 on the dyno we use, but it reads lower then most and like others said, it depends on what Trinity actually does to the head. Mine pulled almost 67hp on KBR's old Dyno. My bros dyno'd the same as mine and his quad kicks mine ass and they are set up identical. No it's not the riders. Numbers don't tell the whole story. Some just run harder then others despite what a dyno says.
I would say the mid 60's for sure. I don't have bigger valves or extreme head work. Mine pulled mid 60's with a slipping clutch.
What do you think mine will pull?
Where is your dyno located. I had my other raptor dynoed at Loveland CO and it pulled low numbers cause of the elevation. If I had to guess, 70.
Hey Guys Just had Mine Dynoed on a factory pro dyno extremely low numbers . Thinkin about getting it redone when i go to rexburg in two weeks.
1 - 11 of 11 Posts
