1 - 16 of 16 Posts
Almost summer and looking what to run on the Raptor.
Barker Duals, K&n Filter, PCIII.
(MABY Boss Noss to come) not sure.
Stock Swingarm
I will be riding at Silver Lake, price dosnt matter just looking for what would be best.
Like what would i run with the Big 3
And what would i run with the Big 3 with Boss Noss.
Thanks guys.
If you're looking for the best tire to race with your buddies at the "testing area" at SL then I'd suggest some 22x11-8 Skat Haulers or Skat Extremes, 8 paddle would be my thought to work best with the big 3 and from what I've seen they still hook well with a boss noss system too.
When I'm not drag racing I have a lot of fun out there with just a set of 20" Sandstars.
I run 22" front sandstars regardless, as I like the wider tire and dual rib, the extra half inch of ground clearance isn't bad either. If you're looking for something light weight for those races I'd agree with a Skat Trak Mowhawk, just get the buffed one to save the weight and still be duneable.
i run 22" haulers. best tire iv had. sand stars are ok but i swear by haulers.
I ran barkers with a K&N intake and a PCIII at Silver Lake, and used 22x11x8 8 paddle haulers...and it was a great setup. The launch was a little tricky because it would float up on a second gear WOT launch on occasion, so I stepped up to a +3 swingarm. That was ideal, I could get a great launch every time, very little lifting and not too much tire spin.
I ended up adding a 20 shot of nitrous to it, and used the same tires and swingarm. That was a fun setup...but not very practical... I could have definitely used a +4 or +6 swingarm. I had to let off the throttle 99% of the time in second gear because the nose was staring up at the sky while racing. The tires had plenty of hook for a 3 mod and a 20 shot, but they weren't too much for general duning.
Like MD said, some 21x12x8 8 paddle haulers or 22x11x8 8 paddle haulers will work great. You may even want to consider some 7 paddle haulers....they will spin a bit more with the nitrous, but if you plan on keeping the stock swingarm...that wont be a bad thing. Plus the 7s will be better for general cruising around.
My guess i will do more cruising around with the big 3. Not much drag racing
What would be the best for high speed general cruising?
Dont care much for Geckos. Have Skat Trac Extremes and Mohawks....love em!
The Kenda front tires are a lot cheaper if your just doing general duning.
Ive got a set of 20 inch 8 paddle extremes for sale they would work great for ya PM me if your interested
I personally have tried 3 different sets of paddles until I finally spoke to Dave at Fullerton Sand Sports, he is the tire guru.
He sold me on a pair of 22 x 12 x 8 with a 7 paddle extreme. At first I was like WHAT that seems so weird and against other opinions on the forums pages asking the same question as yourself. After Dave explained to me a few times why this was a great set up. I finally pulled the trigger and purchased the tires (listed above).
Another thing to consider is the actual casing (mine is a Trexter). This also plays a role in the tire RO and the weight, before you buff the tire. Also run the tires around 4PSI
After owning 3 sets before. I wish I would have talked to Dave before I spent close to a grand on tires.
The hook up is great and many guys are shocked how fast my launch is and I do not even have to let off the throttle since my front end rarely comes off the ground.
For the fronts, I bought the Mohawks and I am very happy with them.
This sounds like a weird size tire. Just talk to Dave and you will better understand. I hope this helps.
1 - 16 of 16 Posts
