when you put her into second, sound slike the gear just spins. As if the teeth on the gear are shot. Could there be any other problem? Do I have to change the second gear? Is it easy? any links?
I have the manual, seems ok but alot of work.
My buddy just had this happen to his 01 and it seems like this is common for that year. You have to split the cases and I cant imagine a more difficult or time consuming repair for a quad. My buddy is giving it a shot since he didnt want to part it out. Theres a site called raptortranny.com that details everything and a search should turn up something since this was common on the 01 660s. Ifyour quad is a beat up wreck time to upgrade, if its in decent shape I wish you luck in the repair. If my buddy puts his back together he will be my hero as he has boxes of labeled parts in his garage and I know I couldn't do it. Great learning experience if you have time and patience.
look at raptortranny.com, theres a writeup to upgrade the 01 to the 02, if you look thru it it'll show you how to assemble the entire trans/motor and how to assemble the gear shafts. excelent writeup with good pics and part numbers. Not especially difficult, just a lot of parts laying around.
got the exact same problem, the 2nd gear is blowed, not the teeth, but the side square-shaped teeth are which get blowed. since they are only 3 to manage the power, thus 02-05 trannys got 4 side squared teeth to handle the power. i got a 03 tranny form ebay 6 months or so ago. good luck on your tranny upgrade
