I just put a direct shift on my raptor 350
I know there is trouble finding neutral but my shift lever is even hard to pull up then it jumps to second what to do
Issue only while engine is running?
How do I fix that
Take some slop out of the lever/tighten the cable, might need an oil change, might need clutch work. Keep in mind as you ride and clutch gets warm, adjustments to the lever are necessary.
