1 - 16 of 16 Posts
Anyone running shorter front shocks that stock or YFZ? I am using YFZ shocks right now with the preload all the way out and would like the lower the front another 2" or so. I was thinking of aftermarket Raptor 250 or 350 shocks. I would like to keep coil-overs with at least compression and preload adjustability. I plan on using the stock a-arms for now, which have been modified for YFZ shocks.
Thanks! :cool:
what ar you doing with the bike? you want to sacrifice travel for stance?
Maybe I am wrong but a lowering kit might work for you. Or make a bracket to relocate the top shock mount 2 inches higher. Just some ideas. good luck.
It's a dune/drag Raptor 660 with an R1 engine.
I don't believe in lowering kits, they just add parts, more to break or come loose, heavier, etc. Buying shorter shocks is ideal way IMO.
Ya I wouldn't use one myself either, just thought it may suite your needs. Shorter shocks are probably the best solution for your bikes purpose. I guess I always first think about the type of riding I do, where longer is better.
blaster front shocks work also
Ig you already have the yfz shocks just buy are dual spring rate kit with the zps(zero preload) Then the bike will site lower but you will have the same travel
Find some aftermarket banshee shock, maybe some works at steelers. I don't know of any OEM shocks from other quads that have compression adjustment.
You're going to lose some capability with the loss of travel.
350 Raptor shocks... They make a beautiful stance...
That looks about like what I'm going for. But aren't the 700 shocks longer than the 660 shocks already?
For my bike i had two pairs of springs so i cut two rings off worked mint. The only down fall is you hear the springs rattle when you wheelie it and come down cuz theres no preload but i love it.
That is what I am talking about with the zps springs. Shorter stiff main spring with a very soft spring on top that does the pre-load for you
1 - 16 of 16 Posts
