1 - 15 of 15 Posts
After searching high and low I found a near perfect match to the factory silver color for our 700Rs:
Dupli-Color Acrylic Lacquer # DAL 1679 Silver Metallic :thumbsup:
So if anyone wants to do some touch up, here ya go :grin_nod:
THANK YOU!!!
I haven't ridden anywhere that should have torn up the a-arms but this thread made me look; I've got surface rust starting where the paint was scraped off by something.
Had I not read this thread - well ... I'd probably be spending a lot more money than I would to buy some sand paper, primer and paint.
Vendor - Rip Ass Connoisseur & Turbo Junkie
PJ1 Make a almost dead on color match called silver case paint.......the color is dead on but has a small amount of metallic more than stock in it......I used it on my frame where I cut brackets off and you cant tell that it wasnt stock
Mike
thank you very much velociraptor - i ran into a tree trail riding the other day and broke the brackets for my front grab bar.... so i had to grind and reweld the little brackets on.... i was trying to find the matching paint...
Thanks again - Plattner
cool... my lower Aarms are bare metal in the front. Thanks!
Hippy said:
http://www.colorrite.com has O.E.M. Paints
so the color is going to be exact :thumbsup:
They didnt have the raptor 700 unless its under a different catagory. I checked yamaha atv for 2006 and 2007 and nothing. Only the rhino. They did have yfz450's so i wonderif they have the same frame paint?
I don't know for sure, but my guess is its the same.. 8)
1 - 15 of 15 Posts
