1 - 20 of 38 Posts
I just bought a used Raptor 700 with Barker Dual pipes, GYTR Pro Flow Intake and a Fuel Programmer. I need some paddles for the dunes. I have heard great things about Skat Trak paddles. I bought Douglas .190 8 inch rims yesterday. I will be doing tree shots. Help selecting a paddle to buy would be much appreciated.
Here I narrowed it down to 4 paddles:
Skat Trak Ripper
22x11-8 10 Paddle
22x11-8 8 Paddle
Skat Trak Hauler
20x10-8 10 Paddle
20x10-8 8 Paddle
21x12-8 10 Paddle
21x12-8 8 Paddle
22x11-8 7 Paddle
22x11-8 8 Paddle
Skat Trak Glider
20x10-8 6 Paddle
22x11-8 7 Paddle
Skat Trak Extreme
21x12x8 10 Paddle
21x12-8 9 Paddle
21x12-8 8 Paddle
I have always ran haulers with no issues. Don't have experience with the other three . I love my haulers.
What size and paddle # are you running?
20*10*10 , I wish they were 22's on 8 inch rims. O ya 8 paddle.
I ran 22" 7 paddle Haulers and could make it up everyhill without a problem.
After my next build i will forsure run 22" 9 or 10 paddle haulers
When you jump with 22's with the stock set up, do the rub your pipes or heel guards?
Are you planning on more engine work? I'm running 22's hauler 8 paddle on my 08. The engine is not stock. The 06 is running 21x12x8 7 paddle haulers. For tree shots I would go with the extremes due to you catching roots or something that might rip a paddle off. They are more rigid at the base. As far as running 22's with duals, the only problem I have ran into is that they slightly rub my pro armor nerfs with heel guards at high speed. I hope this helps you with your decision.
I may drop a cam in down the road but as for piston work no. When your talking about high speed, do you mean 40's or 70's?
For sand dunes yeah. Depends on what sand dunes your talking about.
What dunes are you riding yourself? I run the treeshoots at Walden and definitely recommend the Extremes because of the previous mentioned roots and rocks at creek bottom.
If you were in Walden running a fairly stock bike I would not go over a 20" tire. I run the 21x12x8 Extremes and I chose to gear down my 63hp bike. They were bogging me down on the psycho climbs until I went down a tooth in front. Now I feel the power to bite ratio is spot on.
Discussion Starter · #14 · (Edited)
I go to Sand Mountain NV, St Anthony ID, Little Sahara UT mostly. I want the best of the best paddles lol I have the "Big 3" Barkers, ProFlow and a programmer. This my first EFI bike.
What sprockets are you running? What gear do you launch in, first or second?
Discussion Starter · #16 ·
On your say what HP am I at with the Barkers Proflow w/o lid and efi programmer
13t front/stock rear
2nd gear launch on almost all treeshoots. Its different than hillclimbing a dune face. Theres anywhere from 50' to as little as 5' approach area and its much steeper than dune faces.
I would say in a full topend drag race in fifth gear they start to rub. It's not bad and doesn't concern me. My 06 with the big 3 with barkers dynoed at 50hp, depends on your elevation, that was at about 2000ft. Easystreet, I to used to live in Colorado and loved the walden dunes. Those are some crazy tree shots. That's why I told him he needs extremes.
1 - 20 of 38 Posts
