1 - 10 of 10 Posts
So I was thinking about possibly getting skid plates for my raptor. However I am wondering if the A-Arm skids are different for the long travel A-Arms? I am assuming that if I got them that they wouldn't fit due to them having the jog 1/2 way down.
Most people make there own. Make it from cardboard then make it from Aluminium. I bet it wouldn't be to hard
Why would you make them from cardboard and then again in aluminum, The card board skid plates wouldnt last long............:D:D:D:D
How do most people attach them then? Use another plate of aluminum on the other side of the A-Arm and a bolt through both? What is the best thickness? 1/8" for the A-Arms and 3/16" for the chasis?
1/8 on the a arms and 3/16 or 1:4 under the chassis...... I clamped the a arm skids on........
You may try looking for a used set of good quality A arm skids then take them to a metal fab shop and have them flatten the the bend on the trailing side of each skid plate. Then take it home fit it to your +1 or +2 arms and use a sharpie marker to draw a new bend line. That's what I did with a set of GYTR skids I bought used for around 25. They turned out pretty good even if they don't go all the way up to the frame where the arms bolt up.
Good luck
Discussion Starter · #9 · (Edited)
Ok. I have access to press breaks at the shop I work at just didn't know the best route to go. I know that if you bend aluminum back 9 times out of 10 it will end up cracking. I guess I'll try anything once and if it breaks then I can just use the mounting hardware from them.
Are the 700 skid plates the same as the 660's? I saw one set on ebay that said it would fit Raptor 700 or 660
I'm sure the 700 skids won't be a perfect fit on a 660 but again, if they are good quality heavy skids you won't have any trouble bending them flat and rebending. I did it on the GYTR skids and they look great and have held up for over 40 hrs of woods riding (I may not be so lucky the 2nd time)...
I believe a few of the mounting clamps were missing on the GYTR set so I called ITP and PRo armor and ask them for mounting hardware. One of them sold me a set of 3 or maybe 6 for not to much and the other gave me one or two free I believe. Good luck
1 - 10 of 10 Posts
