I have the Pro Armor skid of my Raptor and I must have over tightened a couple of them and they are stripped. I noticed that the bolt threads into a nut that is welded on to the frame. What is the easiest way to fix this problem?
I guess you could one of two things, drill a larger clearance hole through the stripped nut, then simply use new nuts and bolts to attach the plate, put the new nut on top of the stripped one, or, you could try going up one tap size and retap the stripped nut. Use a torque wrench when you put it on, go a bit less then specified setting and use some loctite.
MK
