I've got a 80hp 778 trail quad which would be better and why? Give pro's and cons please thanks.
OK if its JUST a trail beast then stick with the upgrade that DL provides which you might already have. Those will hold you just fine cause it aint like you will be dumping your clutch.Those look cool but this ain't a race quad it's a trail beast but I don't see dropping 400 in a clutch.
I think those are great if you wanna have a "sleeper" bike. Keeps it all looking stock.heres a pic of my slingshot.............LOL
This the answer I've been looking for. I didn't want to waiste money on one just to need the other one. I'm not trying to skimp I've done dropped enough to cause a divorce so why stop now. I was told along time ago if you gotta do a job twice it wasn't done right the first time. Thanks guys do what ya wish with thread now DD it'll be.I've owned a SS and a DD. Do it right the first time and get the DD. Lighter, less rotational mass, more clamping force. Don't over analyze it. Look at what the pros run.
If you don't want to spend the $$ now on a lockup, do as brettjsand2000 suggested and get the DL spring kit and use OEM clutch.
Spending all that money on a build and skimping on the clutch setup doesn't make much sense IMO. Put the power to the ground.
I'm running mine with 3 stock and 3 aftermarket springs With 3 grams of fly weight. With the lengthened clutch arm it works great pulls easier than the stocker!Good choice. You won't regret it. Run it with an OEM clutch and you won't have any clutch issues. No need for stiff springs either. I ran OEM springs and had no problems.
DL told me go DD use his clutch kit and his springs. His springs are fine but 2 hours into a ride it gets a little hard on the hand I think just 3 soft oem springs and 3 stiff springs will work fine.I'm running mine with 3 stock and 3 aftermarket springs With 3 grams of fly weight. With the lengthened clutch arm it works great pulls easier than the stocker!
Yup that and a lengthened arm!:thumbsup:DL told me go DD use his clutch kit and his springs. His springs are fine but 2 hours into a ride it gets a little hard on the hand I think just 3 soft oem springs and 3 stiff springs will work fine.
