1 - 10 of 10 Posts
stems sold
Thanks for another smooth transaction Brandt
Good luck this year in racing!
Up for grabs
I have a plus 1.25 blue stem
With the houser 1 1/8 bar clamp
150 with out clamp
If clamp needed will work something out
The black one is stock length
With a 7/8 houser bar clamp
150 with out the bar clamp
The Stem bottom is made from 4130 chromoly steel and tig welded. Adjustable steering radius.
adjustable pitman arm sold
Pm if interested
Thanks
Sent from my SM-G955U using Tapatalk[/color]
Will these stem fit a 660? Also, if they do fit will i need longer brake and clutch cables if i chose the longer stem?
Discussion Starter #3
On the 700 I didn't need longer brake line stock worked with plenty of slack
As far as fitting 660.
I would contact houser and see
Thanks
The Raptor 660, 700 and 450 stems all mount the same, but have different length. I think the 660 is the shortest but don't quote me. It's best to measure yours and compare.
Discussion Starter #7
Sky high bought the black stem and bar clamp
The rest is still available atm
Thanks for a smooth transaction bud.
I'll pack it up and send shipping info to you after work..
Thanks again guys
Discussion Starter #10
Pitman arn has been sold.
Thanks Brandt for another snooth transaction
Other stuff listed is still up for grabs
1 - 10 of 10 Posts
