Can you can with the spark arrestor out with out any problems? the rest of the bike is stock, its a 07 700
Not sure I follow what you are asking, dont know if anyone else will either. If you are asking if you can run without the spark arrestor without changing the fuel map then the answer is probably not a problem but these things run lean from the factory so check your plug and make sure that it is looking OK.
Thanks, that's what i meant, if I could run without it in. It likes to hesitate when coming out of the cornings or in the whoops. I never ran this bike with the spark arrestor in, so i'm not sure if thats why it's doing that
