1 - 9 of 9 Posts
Got a quick question how does my spark plug look? Spark plug Fastener Automotive ignition part Auto part Automotive engine part
Finger Hand Wood Auto part Spark plug
Light Lighting Font Darkness Finger
looks to me its really lean, but i cant find anything on-line that looks like that. The raptor runs great and idles great with the current map i just uploaded on it.
I am not much of a plug expert but from what I have seen that seems to be really on the lean side. You want more like a tanish color in the middle ring. It can be a little tan with gray in it but not that white.
You can refer to this site for a bunch of pictures of plugs:
The quality of the pics aren't the best from this page
http://www.dansmc.com/spark_plugs/spark_plugs_catalog.html
Here is another page that explains all about the spark plugs
http://www.4secondsflat.com/Spark_plug_reading.html
Thanks,
Silentrath
Looks ok.
Mine is a really light gray almost white and it is stock.
To me the first looks good, the other two look a little lean, but I am guessing it is from the camera flash.
Ok thanks guys, maybe ill try and ritchen it up a little to be on the safe side, would it be easiest to just do that on the programmer with the low mid high settings? I have a pc3. I also have downloaded the powercammander program on my lap top but all the numbers are kinda alot to take in. This is the first ever efi tuning ive done in my life
mods are big gun es slip on, power bomb header, K&n with prefilter and no air box lid, if anyone has a map for that or somting very similar let me know, and wouldnt it be easier to fine tune the map i used from dyno jet insted of going to a base map like you said? ^^^^
Im currently running a little bit of injector cleaner through it, ive herd that that might affect the color of the spark plug, is this true?
1 - 9 of 9 Posts
