1 - 20 of 26 Posts
Some know what is the speed sensor cable?
I need to know which one comes to the ECU because I think the cable has no continuity but I have to be sure which one it is
Enviado desde mi SM-N9600 mediante Tapatalk
The 'blue wire' mod works on the early years, BUT, is a obsolete now. Instead, remove the round, plastic switch from the clutch perch. Then zip tie the switch, connected to the wires, out of the way. You'll also be able to start the bike in any gear.
Not sure if the blue wire mod actually worked, others may know.
Discussion Starter #4
friends do not understand, I know what is the poprque cable I have an error 42 (new sensor) and because I already tested all the cables and none gives me continuity therefore it seems that it is the broken cable but I have to be sure what it is to replace it
I don't know what year yours is but '06 - '09 is covered in my manual. It shows a solid blue wire to the speed sensor, is the 4th wire into the ECU. And also a solid black wire to the speed sensor, is the 8th wire into the ECU.
Discussion Starter #6
excellent, I think I have another manual because I didn't see it on mine, thank you very much
Send a valid email to Morphrider for a free, upgraded, digital manual with wiring diagrams.
Yup, send me a valid email And what year you have. I have the revised edition for 2013 and newer machines.
Discussion Starter #9
mine is an old 2006, and check all the cables and if they are good, I think I will buy another sensor to try, (it hurts to spend so much on a sensor that is useless -_-)
Have you tested the sensor? It's isn't hard.
Do you have aftermarket dual exhaust? Check the wire harness behind the exhaust on the right side for contact and burning from heat.
You have a code 42, what are the symptoms? Will it run?
Disconnect the battery for 5 minutes and the check for codes again.
Discussion Starter #13
It works well, I have months with it, it is annoying because the light is always on, according to the test (video) is the sensor bad?
what do you think?
So, the speed sensor is reading correctly, but, does it stay at 4.8 volts when you stop turning the axle. I would think it should drop back to zero.
Discussion Starter #15
Is it damaged? It's almost $ 100 replacement just to try..
This say the manual
If your volt meter is accurate, it shows 4.87 volts. That is .07 volts out of range, I'm not familiar with bad speed sensors or if that would trigger your check engine light and code.
Have you tried disconnecting your battery?
I have some I can send you, just pay postage. BUT, I have no way to test if they are good.
How we do ?
I'll need your address information and find out how much international shipping is and you pay that in USD. Then I post it to you with no charge for the parts.. BUT, as said, I have no way to test them and can't guaranty they are good.
1 - 20 of 26 Posts
