thanx boom I just cut mine what is this gonna actually do for me?..I know that this sensor retards timing after 7k right so will I be able to get some more horses at a higher rpm?..
Guys DONT cut the cable !
Your gonna need to plug it back in to reset it when the check engine light eventually comes on.
Then just roll it a few feet until the check engine light goes off, then unplug again and your good for a while.
hmm why is this my first time reading about this in another thread today. As much as I have researched this site. Any other tricks to gain speed. I know basic 3 and 15T. Now this. I know tires. Anything else? besides engine work ported head, piston and cams?
I didnt search specifically for speed sensor because I didnt know about it. All the other Mod threads I've been in said nothing about this. I know its only for top speed. You dont like that?
From my searches and research I've found its a crap shoot on if your check engine light will come on, If we plug it back in and roll it to get it to come off, will it then stay off if we unplug it again?
you get approx 8hrs it changes from bike to bike and by being discount it doesnt enable the sensor to slow down your output shaft to 6500 rpm instead of the 8,000rpm you normally get in every other gear which off course will give you more mph in the top end when your close to the limit . Thats what ive made out of it anyway some people have put in toggle switches so they can just turn it on and off to reset it but im still waiting on which wire it should be connected to so far i think its the white 1 but dont quote me on that as i dont know for sure yet .
Okay could someone help me out here? There are 2 white plugs in the same area a small one and a large one. I un plugged the large one and my top MPH does not change from 75-76 MPH. I un plug the small one and the quad does not run. Am I unplugging the wrong plug? is it the black plug on the actual transmission I am to un plug??? ANy help would be appreciated. I tested this on the quater mile track thats how i know these MPH numbers are accurate.
guelph you are unplugging the wrong one if you unplug it and the quad wont start after that
you are in the right area of the quad but you need to look around for the other white plug that pulls apart, mine on my 07 was ziptied to a couple other wires from the factory
