I was reading the thread about this and was trying to figure it out. If you disconnect it does your check engine light come on or not? Or is it just the luck of the draw?
Your so crafty Steve! :lol: sorry I have ADD... :Crafty Steve said:Different bikes have been getting results with how long before the engine light comes on, but you just plug it back together again and ride 10m or so in 1st gear till it goes out and your good for the next session . The speed sensor only limits the rpm of the output shaft in 5th gear, as far as i can make out back to about 6500rpm were all the other gears do about 8000rpm so by disconnecting this and having an area big enough to do this speed you should pick up a higher top end speed . The more performance mods you have done to your bike the greatter the noticeable difference but only in top gear .
Hope this helps :grin_nod:
It will come on......8 hrs seems to be the magic #........mine went 20 or so...........and I know a few that havent come on at allRaptor0731 said:I was reading the thread about this and was trying to figure it out. If you disconnect it does your check engine light come on or not? Or is it just the luck of the draw?
