1 - 20 of 20 Posts
I HAVENT EVER HEARD ANYTHING ABOUT THE SPEED SENSOR IN TILL I CAME TO THIS SITE BUT I WANT TO KNOW IS IT TRUE DO U NEED TO UNHOOK IT FOR IS THAT A THING ONLY FOR STOCK BIKE(CAUSE I HAVE A BIG GUN CDI BOX OVER REV) BUT IF SO EXACTLY WHERE IS IT AN DO I NEED TO DO ANYTHING ELSE OR JUST UNHOOK IT.
what do u mean by no one knows what it does it should not stop u from topping out in fifth it only works in fifth but if u can show me a pick of where its at but all the pics i have seen the plug is under the seat on the left side where the harness opens up i will find the pic an post it.
Here are some of the pics from the another thread
This is the speed censor what it does is in 5th gear at somewhere around 7500 it starts de-rating your timing and ultimately governing your top speed.
Unplug that thing, it will not effect your computor or give any ill side effects to your bike.
Is that a pic of a 700 or a 660?? I never saw that on my 660 man.
thats a 700
if i had to guess i would think that the speed sensor helps to adjust the ignition timing curve. not sure but that would be my guess. mine is plugged in and i can guarantee it doesnt speed limit the machine. at least not until 85 or 90 as that is the fastest i have had my quad, it feels unsafe after that.
phucker, I agree, thats the most likely scenario, but if the stock cam gives up before then what would be the point. And how many individuals come to mind that have pulled it? If it was being used to control the timing wouldn't the guys that aren't using it have noticed? Or is there another input for controling the ignition curve.
John said:
i dont know about all this speed limiter on a 660
It does exist in all years.
Look in the online microfiche, in the electrical area, you'll see it.
The wheel it rides on is on of the last things installed on the counter shaft.
Maddog56 said:
Now I'm confused :3question: :'(
My bike will go faster top end that I'll ever care to so I guess I won't worry my little head about it. ;)
ME TOO!
this is the best I could find---denotes on bottom of page 5,
http://www.autoshop101.com/forms/h36.pdf
I'm moving onto a different thread,..my hea hurts now :banghead:
its there an it works it retards the timing so bike will be more safe at top speed for the engines sake an the riders
1 - 20 of 20 Posts
