does any body know the lenght of the standard rear spring unloaded?
and would it matter if i put a longer than stand one on the shock?
If it's too loud your too old
Stock rear spring unloaded off the shock 10 1/8" A longer spring may stiffen it up depending on the spring rate to start with. Longer doesn't nesasarally mean stronger.
the newer rear spring i ordered for my weight was around 1/2" shorter then the stock spring... but with the preload screwed down its way stiffer.
