Yep, do a search on hear for a gearing calculator, lotsa good info.05rappy said:am i getting more speed with my stock sprocket with a 22 inch tire
SS is right, 16 won't fit without removing the chain guard. And 38 is the smallest you can go on the rear without clearance problems. 15 is still a tight fit on the front with the guard and probably won't fit with some aftermarket case savers.akawilliam said:If looking for top speed should i go to a 16tooth front? Im interested in buying a 12tooth and 16 and change when needed.
