if i want my bike to get off the line faster what should i get? what are some good prices? and do i have to change anything else when changing the sprockets?
12 tooth and start in second gear,..feather the clutch out hard......I'd at least have a pipe or it might not work so good.
ive got a slip-on, jetted, hotcam, and a k&n
Depends on your tires. If you have a good set of knobby's and your in the dirt rev high and practically dump it. That maybe what you are saying RT but have raced/trialed everything with these HD's on a 12tooth and breaking them loose tends to holeshot people. Except in the sand :eek:
I've never had a problem getting out of the hole with any razors or holeshot hd,...the trick is not to dump the clutch,...feather it hard.
i mainly ride in the sand. about once a month i will go to the track and ride. and i just have stock tires for now.
