1 - 9 of 9 Posts
If I put a 42 tooth sprocket on the rear, what size sprocket should I put on the front and would I feel a difference if I change the sprockets?
I do alot of trail riding.
ThNks
Going to a 42 on the rear you should see a large difference in torque. If you want even more you could go to a 12 on the front. If you want more speed go with a 14 or 15. But for trails a 13 or 12/42 is good. However if your front sprocket is worn I would go ahead and buy a 12 for the front.
ThNks
Going up two on the back isnt quite same as going to a 12 on the front from a stock 13................
I used a 12 - 48 for oval tracking and just loved it............but that was me...........:)
What do you think your top speed was with a 12/48? Im thinking of going to that ratio for trails. And would like to pull wheelies in 3rd and 4th gear.
My setup with the 12 - 48 in oval was complimented with a wild engine that could rev 9300 rpm, top speed was about 80 mph, the engine had a 3 plughead, HV porting, 686cc, 39mm FCRs, Curtis exhaust, Reprogrammed Dyna FS CDI, and to attain the top speed the top speed limiter was bypassed............:D
It's simple math - with stock tires and sprockets, top speed is limited by the speed limiter to about 75mph.
SO when changing output ratios, the speed limiter will do approximately the following:
going from 13 to 12 = 12/13ths of the original top speed (12/13 = 92%) --> 69 mph
going 40 to 48 = 40/48ths of original speed (40/48 = 83%) --> 62 mph
Combining = 83% of 92% = 76% --> 57 mph
You get so technical..............:D
That's meeee.
1 - 9 of 9 Posts
