Can someone suggest me a sproket setup and explain to me why i would want to go higher in the front or lower in the front and same for the back..
Thanks
06 rap 700
Full HMF pip
efi controller
prodesign intake no lid
I HAVE 15/38 FOR DUNES,15/36 FOR WOODS . THIS WORKS GOOD FOR MY WEIGHT. WEIGHT AND HOW MANY MODS YOU HAVE DONE ARE A HUGE FACTOR IN CHOOSEING YOUR RATIO.
WITH THOSE MODS AND YOUR WEIGHT I WOULD TRY THE 15 IN FRONT FIRST AND SEE HOW IT FEELS. IT SHOULD FEEL A LOT FASTER AND STILL PULL HARD. IF YOU DON'T LIKE THAT PUT THE 14 BACK ON AND PUT A 36 TOOTH IN THE REAR. THIS WILL GIVE THE SAME FEEL AS IF YOU COULD FIND A 14.5 TOOTH FOR THE FRONT. GOOD NEWS IS THE FRONT WILL ONLY RUN YOU ABOUT FIFTEEN DOLLARS FROM ROCKY MOUNTIAN ATV. THE BAD NEWS IS THAT IF YOU DON'T LIKE THE 15 IN THE FRONT, THE 36 TOOTH FOR THE BACK IS 2 TO 3 TIMES MORE MONEY. GOOD LUCK.
