After greasing up all the ball joints, tightening up all the suspension bolts, spraying WD-40 on just about every bolt on the suspension....MY RAPPY WOULD STILL SQUEEK! :mad: I was tired of listening to that squeeky sound every time I sat down on the bike. The cause was the upper mounting bolt to the rear strut. Take some WD-40, spray it, and take that annoying squeek away! :thumbsup:
GO BLUE!!!
Mine does that too, I put some grease in there. It lasts for alittle while then it comes right back. sucks
Thanks for the tip :thumbsup:
you can also try alittle castrol chain lube can fix it for about a month or so before having to redo it but if i dont get some aftermarket shocks soon ill be lookign into taping it with a greese nipple :thumbsup:
