1 - 11 of 11 Posts
i have a stage II web cam with a 11:1 je piston and it shure does make alot of cam or valve noise at idle. does anyone know if this is normal.
Just make sure your valve are adjusted right besides that they are a little nosie from what I've heard. Mine is.
With a stage two you had to do get the stiffer springs right? It is normal for them to make more noise. Not being able to hear yours I don't know how much louder yours are. Proper adjustment, as stated before, is crucial too.
Craig,
i do have the heavy duty springs so its probly okay. i have about 10 hours on it since the install should i adjust the valves again.
Stage II+ cams will increase the noise due to the ramp rate of the lobe profile, not to mention the increase in accelerated movement (throttle response).
If they are adjusted right I am sure you will still have very noticeable valve noise.
Just my $.02
Just my $.02
is stage I more quiet :3question:
Suffering from Chronic Tinkeritis
Just my $.02
Not mine, they tick more than stock
so your saying stage 3 makes less noise? and have you dyno'd how much more power stage 3 gives then stage 2? thanks.
......I thought there was a gain of a couple hp on the topend with the stage III...
1 - 11 of 11 Posts
