1 - 2 of 2 Posts
just rebuilt the lower end. However i have a nasty starter clutch noise and don't understand how i got it. Never did i have noise before in this 700. So i removed the mag cover only to find the starter clutch dragging on the inside of the cover. Did i forget a shim???? I have no ideal. ( fresh sidecover gasket). It almost seems the mag cover gasket is to thin? Am i going out of my mine or did i put this together wrong.
Please help me.
1st time post.
its really hard to help without a little more detail. the gasket is just enough to keep the oil from comming out so thats not an issue.
what else did u do to it? might be something else. did u do a crank ect in. what lower end build did u do? more info will help to guide you in the right direction.
1 - 2 of 2 Posts
