IF you are asking about the starter one-way clutch/bearing - symptoms are:
1) starter turns but engine doesn't, or
2) starter engages engine but occasionally freewheels, or
3) grinding, disgusting noise from left side case everytime you start
Anybody else with classic symptoms to add?
Wallet is feeling a little heavy :)
I found my tranny was a little noisy too. Primarily 2 above. How hard is it to replace. There are step by step instructions on here. If you have the tools the feedback on various threads seems to be that its reasonably straight forward. I didn't have the tools so dropped it into the shop. 2 hours labour. Got a couple of other small things done at the same time also, a few leaking air valves on wheels, reroute the throttle cable - was getting half throttle on full right lock - probably messed up when I had it stripped last time.
Hope this helps
