Fixed up, thanks for the support.
Disconnected plugs and traced the problem to the starter button. Tried to take the switch appart, but could not get the thing out. After long struggle tested again and it seemed OK..... Put everything together and it worked. Loose contact /dirt ?
Suspension was OK. Front wheel was bend.
Shorting the starter relay out, as decribed below, is a good trick to know.
